For this charging issue, please try the following troubleshooting steps:
1. Check if the base station's plug is loose to ensure the charging dock is powered. Observe whether the indicator light on the base station illuminates normally. If it lights up correctly, the base station is successfully powered.
2. Position the robot 1-2 meters in front of the charging dock and briefly press the return-to-dock button. If it fails to return to charge, contact our after-sales team. If it returns successfully, verify the following:
① Position the charging dock against a wall, ideally with 5cm clearance on either side and no obstacles within 1 meter in front;
② Keep it away from signal interference sources like routers or televisions;
③ Ensure no reflective surfaces (e.g., mirrors, windows) are directly opposite the dock.
3. Check if the robot's drive wheels slip, get stuck, or become trapped during operation.
4. If the above issues are ruled out, restart the robot and attempt cleaning again.
5. When relocating the base station, place the robot on the base station and initiate cleaning tasks from there;
6. If issues persist after restarting, reset the robot, relocate the charging dock to an open area, and run the cleaning task again to verify if the problem is resolved;
Should the issue remain unresolved, we recommend sending the device's SN and invoice to our after-sales team for further troubleshooting solutions.
na.official.site@mova-tech.com
