After a few cleaning runs, I started paying closer attention to how Alfina handles edges and corners since that’s usually where debris tends to get left behind.
One thing that stood out is the FlexBrush system. The side brush actually extends outward when it gets close to edges, which helps pull debris in from areas that would normally be just out of reach. You can see it reaching along walls and around furniture instead of just passing by.
On the mopping side, the FlexMop Roboswing behaves in a similar way. When Alfina gets near edges or tighter areas, the mop adjusts its movement to get better coverage rather than just moving straight through. It’s subtle, but it makes a difference in those spots that typically need a second pass.
These features help make the overall cleaning experience feel and look more complete.
#GetYourV50 #MOVAV50 #sponsored TranslateView Original Text
