MikeR1766
[V50 Ultra Complete] MOVA V50 Ultra Complete Thermo Mopping with Duo-solution system
The MOVA V50 Ultra Complete takes mopping seriously! Thermo mopping means the vacuum uses warm water to help tackle those stuck on messes, the dual spinning mops exert solid pressure down onto the floor, and even have the ability to flex so they can mop uneven floors.
The Duo-solution system enables you to use two different solutions throughout your home, in my example I'm using MOVAs pet odour solution in front of my cats litter boxes and MOVAs multi surface cleaner throughout the rest of my home. stronger odour fighting delivered only to the spots that are needed!
The V50 Ultra Completes dock is truly a do-all station, using 20 combined jets that spray hot water up onto the mops to thoroughly clean them of debris and particulate matter, and then a hot air system that dries the mops to prevent mildew and the associated smells.
Oh and did I mention that all of the above happens while I'm not even at home? I come home from work to clean floors and the relaxing reminder that one of my chores has been taken care of for me. I'll never go back to mopping!
Love the kitties watching!
2026-4-18 12:17:07 CA Translate
best part is coming home to a clean home!
2026-4-23 23:32:23 CA Translate
UID:ZZ695667 CA
