MikeR1766
[V50 Ultra Complete] MOVA V50 Ultra Complete Base Station
I know the V50 Ultra Complete is the star of the show, but I feel like the base station needs some praise too!
So much happens at the base station, from charging and updates to facilities that help the V50 keep your home clean and pleasant.
The base station cleans the robots mop pads with hot water and dries the mop pads with hot air, but did you know that the base station also refills the robots on board water tank? You can even choose if it fills the robot with hot or cold water. (Thermo mopping feature)
Not only does the base station help clean the V50 by doing the above but it also empties the robots on board dust bin into a vacuum bag, containing up to 100 days of debris before needing to be changed!
The base station even cleans its own wash base (where it washes the mops) and empties that water into a dirty water tank, you are notified when it’s time to empty the dirty water tank.
That’s really all you have to do, make sure it has clean water and empty out the dirty water… occasionally check to see if the vacuum bag is full and top off your floor cleaning detergent.
It’s Binx and Nala approved.
Love the base station too
2026-4-25 23:42:41 CA Translate
UID:ZZ695667 CA
