AE626981
[V50 Ultra Complete] Mova V50 Ultra Complete: An honest review
While testing the features on the Mova v50 Ultra Complete, I have discovered some advantages as well as some minor problems when I put the Mova v50 Ultra into daily use.
The Goods:
The Mova v50 Ultra is amazing when it comes to smart navigation, mopping, and vacuuming. It's incredible that this piece of technology could completely replace all of your daily mopping and vacuuming tasks, even when we have a cat and the mess is there every day.
The Problems:
No matter how good a product is, there will definitely be some problems, although they’re just some minor inconveniences. We have a very special mirror sliding door, where the Mova V50 seems to get confused and decides to map it as a room, but the good thing is, it never actually tries to bother to get inside. When it found that it couldn’t make it through the mirror door, it simply moves onto other rooms. The second problem is that sometimes the robot struggles to go back to the base station; it couldn’t align with the base station and hit the edges of the base. However, this problem seems to only happen occasionally.
Overall, I would give the Mova v50 Ultra Complete a score of 8/10, it is definitely different than other robots you will see out there in the market. Although with minor problems which doesn’t really affect daily use, it is still a massive upgrade.
#sponsored
Hello, here are the common reasons and solutions if your robot cannot find the charging base station:
If the charging base is powered off or moved manually, please connect it to power and place it back in its original position.
If there are obstacles on the base tray or the surrounding ground, please clear away the items in a timely manner to keep the area unobstructed.
If the robot gets trapped or gives an alarm during cleaning, you may manually place it back onto the charging base.
If the ground under the charging base is uneven, please position the base on a flat and level surface.
In case of system abnormality, place the robot 1 meter in front of the charging base and press the Recall button. If it still cannot return automatically, please contact our after-sales team for professional
UID:AE626981 CA
