rvs007
[V50 Ultra Complete] Easy to Setup & Start Cleaning!
Getting the Mova V50 Ultra Complete set up couldn't be easier.  First scanned the QR code on the robot to add it to the MOVA app, press the two buttons on top of the robot, and let my phone connect to it.  On the robot itself, everything is ready to go except for the two round mop pads which I manually installed.  It is held on magnetically.  On the base station, I filled up the clean water tank, and added the cleaning and pet odor detergents to the respective reservoir.  It was ready to go!
First it did a quick mapping of our main floor, which took about 5 minutes to complete.  It silently roamed the main floor from room to room, mapping out the layout of our house.  The map that was rendered in the app was precise and represented all the rooms of our main floor.  I did have to make manual adjustments to the floor type and direction of hardwood flooring, and tweak some of the room assignments because of our irregular floor layout.  But the app is very intuative and easy to use, and we got the map customized in no time.
All in all, the time needed to get the robot ready for cleaning is quick and requires minimal effort.  Once it's set up, subsequent cleaning tasks can be initiated through the app, automatically scheduled using the app, or started by Voice Command.
voice command is neat with this
2026-5-10 01:37:33 CA Translate
UID:ZC787769 CA
  • 6Posts
