AE626981
[V50 Ultra Complete] Mova V50 Ultra Complete, near a month
I have been living with the Mova V50 Ultra Complete for nearly a month, and the dust bin still isn't full at all, which is impressive since I have a scheduled cleaning task for the whole floor every single day, and cat fur is everywhere. The Mova V50 Ultra have an impressive dustbin capacity.
The error rate (task failure) is also extremely low, even when my home layout often changes. The time the robot actually asks for help is when the water tank is empty, in which case you have to manually refill the water tank.
The brush is well designed, after nearly 30 days of usage, there is zero jam, and there's no hair/fur stuck on it.
There are some issues with the pet monitoring feature though. Even when the robot is close to the router, the live feed often feels laggy and sometimes just frozen.
Overall, the Mova V50 Ultra Complete is an amazing choice if you want a solution that is set it and forget it, it cleans up your floor sometimes even without you noticing, and you come home with a freshly cleaned floor.
#sponsored
2026-5-11 02:20:30 CA Translate
UID:AE626981 CA
