[MOVA Diver A10] Three “Filter Levels”: Why Your Pool Still Looks Dirty After Cleaning?​
A situation many pool owners have experienced:
The robot finishes a full cleaning cycle… but the water still looks a bit cloudy.Or it suddenly stops midway with an “overload” alert.
In many cases, it’s not about the robot working harder —it’s about whether the filter is right for the job.
You can think of the filter as the robot’s “breathing system.”
If it’s too coarse, fine dirt slips right through.
If it’s too fine, it clogs quickly and slows everything down.
So, what’s the difference between filter levels?
1️⃣ 180 Micron Coarse Filter
Handles the obvious mess
Best at catching larger debris like leaves, twigs, insects, or hair clumps.
Water flows through easily, so the robot can keep running without interruption.
When it makes sense:
After a storm, during fall, or when opening the pool after a long time.
2️⃣ 100 Micron Standard Filter
The “everyday” choice
Captures smaller particles like sand, seeds, and general debris you don’t always notice.
It strikes a balance — good cleaning performance without slowing the robot down.
Regular maintenance for most backyard pools.
3️⃣ 3 Micron Ultra-Fine Filter
For when you want crystal-clear water
Designed to trap very fine particles like dust, pollen, or early-stage algae.
It can noticeably improve water clarity — but it also clogs faster and needs more frequent rinsing.
When the water looks cloudy, or after heavy pollen/algae periods.
What actually matters?
It’s not about choosing the finest filter.
It’s about choosing the right one for what’s in your pool right now.
Using the right filter doesn’t just make the water cleaner —it also helps the robot run smoother, longer, and more efficiently.
Thank you for all these very useful details! 😊 It really helps to better understand the differences between the filters and choose the right one depending on the pool’s condition.
2026-5-13 00:25:11 CA Translate
3 micron filter is impressive.
2026-5-13 23:25:11 CA Translate
