neil.patel
[Lidax Ultra 1000] Major issues today. Unit is unusable
Anyone else having issues with their Lidax 1000 ultra since the latest software?  My map and unit which has been working flawlessly until now went completely off the path and got stuck. When I tried to correct it kept running into my cars. I factory reset the unit and tried rebuilding the perimeter map and it never senses the starting position return even though I’m immediately on top of the starting position upon completion. Each mapping session yields different results and because it isn’t able to close the boundary I can’t use the unit to practically cut the size lawn. I started a ticket with support but I’m very disappointed having only owned the unit a handful of months so far.
6 Comment
Hello, we apologize for the malfunction occurring on your device after updating to the latest firmware. Please troubleshoot step by step as follows:
1. Clean the sensors of the machine to make sure they are not blocked.
2. Clear the cache of the App completely. Unplug the charging dock power supply, leave it powered off for 5 minutes and then plug it back in.
3. Try remapping the lawn again.
If the problem persists after all the above operations, please upload the device logs via the App and provide your machine serial number as well as the current firmware version. We will analyze the log data. If a hardware fault is confirmed, you need to contact after-sales service for a solution.
2026-7-5 12:57:22 CA Translate
Hi there, I have done those things and have not had any success with the remapping. The boundary still shows that I've returned to a spot 15-20 feet away when I am directly above my starting position. I've not had this issue when I first bought the unit and was cutting it for over a month. Something changed after the last update which was making the control erratic. I can confirm both the lidar and camera have been thoroughly cleaned and the wheel assembly and decks are all free of debris
2026-7-7 21:46 CA Translate
Hi there~ You mentioned you had submitted a support ticket. Has your issue been resolved? We have read your detailed reply. If you still require assistance, please upload the device logs, provide your machine serial number, specify the exact time the fault occurred, and keep your robot online. We look forward to your reply.
2026-7-8 11:03:11 CA Translate
Hi there, my issue has not been resolved no. They are telling me it needs a repair service and needs to be shipped back. This is a really poor experience after only 4 months of ownership and maybe 8 grass cuts at most. I also don't have the original packaging so sending it back safely is going to be a nightmare. This should be replaced and I return the unit in the replacement box at this point. I've sent the screenshots/serial to support and a full video of the behavior. SN: G2529C5BQUS00285A4
2026-7-11 04:09 CA Translate
Hello, if you have already contacted our after-sales service team, we will forward your new requirements to them. Before that, please send us your service ticket number via private message so we can quickly retrieve your ticket information for follow-up.
2026-7-14 15:13:04 CA Translate
UID:OZ472249 CA
