🚀 [Full Guide for New Users] Control When Your MOVA Robot Vacuum Empties Its Bi
    "Why does my robot keep going back to base?" / "How to make it empty more often?" - We've got you covered!
    🔧 Part 1: Set Your Preferred Emptying frequency
    1. Open MOVAhome App → Go to your robot's map view
    2. Tap ⋮ menu (top-right corner)
    3. Choose Base Settings → Auto-Empty
    Choose your mode:
    🆓 No Emptying:Never auto-empties
    🕒 Standard Mode:Empties after scheduled cleaning tasks
    ⚡ High Frequency:Empties MULTIPLE times per task (smart detection)
    🌿 Low Frequency:Empties after 3 FULL cleaning cycles
    Pro Tip:
    🐾 Pet owners: Switch to High Frequency Mode if you have shedding dogs/cats – prevents hair clogs!
    ⚠️ Part 2: Immediate Emptying
    (When you need it NOW)
    1. From map view, tap Dock station icon (bottom-right)
    2. Hit EMPTY NOW
    Robot will:
    → Return to base
    → Empty within 20 sec
    🗨️ "I use [Mode] because..."
    (Click reply to share your setup!)
    You should give information on how to use the vacuum on multi floor homes. There is absolutely no information on it in the user manual. Do we just pick up the vacuum from the dock and take it to another floor.
    2025-12-8 07:25:01 Translate
    Yes I’d like some information on this as well. I’m assuming you would have to bring the whole base and everything
    This is a great review.
