🔧 MOVA Shortcuts Masterclass: Time-Saving Hacks for Custom Cleaning Routines 🔧
    🌟 What Are Shortcuts?
    Smart command combos that automate repetitive tasks - customized for your MOVA robots!
    🍞 Real-Life Example: Sunday Breakfast with Kids
    Skip manual zone selection for crumb cleanup!
    → Activate your pre-programmed "Sunday Breakfast" shortcut
    → Robot precision-cleans just around the dining table
    → No whole-room cleaning needed
    🚀 How to Create Shortcuts
    Open MOVAhome app → Tap "Add Shortcut"
    Option 1: Use ready-made shortcuts (➕ icon)
    Option 2: Build custom shortcuts (Tap "Add Shortcut")
    ⚙️ Customization Options
    • Works with multi-floor maps
    • Combine:
    ✓ Specific rooms/zones
    ✓ Cleaning intensity levels
    ✓ Scheduling
    • Edit/Rename/Delete via 3-dot menu
    👇 Your Turn!
    💬 Which one are YOU?
    🔹 Shortcut pro: Drop your best combo below!
    🔹 New to shortcuts: What routine would save you time?
    🔹 Need setup help? Ask us anything!
    Let's create smarter shortcuts together! ⚡️
