Thank you for already trying so many troubleshooting steps. You may also try the following:
1. Check whether the water pipe is properly installed, seated in the limit slot, free of kinks, and verify there are no foreign objects inside the water tank.
2. Open the cover of the clean‑water tank and check if its sealing rubber ring is correctly positioned.
3. Remove the clean‑water tank and inspect whether the sealing ring on the base station is damaged or missing.
4. Reinstall the clean‑water tank and press it firmly downwards.
If the issue persists, please contact customer service for further support. Email:
