QA554576
[P10 Pro Ultra] Cleaning mop after each task.
I wondered why it cleans its map even when it's only vacuuming in custom cleaning with the mop disabled. It seems like a waste of resources. The logic here doesn't make any sense. It should only clean the map after mopping, but in my case, the task is only vacuuming.
Under normal circumstances, the robot should not automatically clean the mop when operating in vacuum-only mode. To help us further investigate this issue, we kindly suggest that you send the device's serial number (SN), proof of purchase, and relevant screenshots of your settings or a video of the issue to our after-sales service team. Our after-sales and technical teams will analyze the situation as soon as possible and provide you with an appropriate solution.
Thank you for your understanding and cooperation. We wish you a joyful holiday season.
mova.usmkt@mova-tech.com
2025-12-24 16:44:32 CA Translate
QA554576Thread Starter
Its weird that this issue occurs. Is there update coming up?
UID:QA554576
  • 5Posts
